I am replacing an old stove with a new EPA one which requires 6". Due to clearance issues I am installing double wall 6". The existing stove pipe is single wall 8". I was hoping to install a 6" to 8" adapter right below the ceiling support box to eliminate messing with the support box. Does such an adapter exist? Also, the overall height of the chimney is about 12' and the stove (Englander 17-VL) recommends 15' of 6". I was planning on just increasing the class A chimney with additional 8" if there was a draft issue. Do you think that will work or what would you recommend?
