Hello everyone! I'll be installing my 3rd woodstove soon, but the first that will be in an alcove. I'd just like to double check the ceiling clearance for a Drolet 3000. The alcove height clearance is 74" in the manual, but it goes on to suggest that with a proper heat shield the ceiling clearance can be reduced 50%. My plan is to build a kind of drop ceiling into the alcove, using steel and cement board anywhere below 74", then to put a metal heat shield with spacers to be extra safe. I've attached a rough sketch to help illustrate. I'd appreciate input from you guys, thanks!
![Double checking clearances Double checking clearances](https://www.hearth.com/talk/data/attachments/306/306470-2b77f4b9c48defa0d91d608b7f7990ca.jpg)
