double barrel single barrel or water heater tank stove?
greythorn3
1,002
Alaska
wheelordie.com
anyone ever used the double barrel stove kit? is it that much better then the single barrel? i dont see how it would really be any better as it seems to be just a large chimney the 2nd barrel on top.
also thinking of doing a water heater stove, as i got a ele water heater layign around.
something for my drafty pole barn anyhow.
I had the single barrel. Then converted it to double barrel. Got more radiant heat with the double. I eventually moved it out of the basement, cut doors in the ends of the top barrel and put two rows of racks in and made a monster smoker out of it.
Use one a couple weekends a winter at my buddies cabin. The top chamber is just for more surface area and works sorta like a large heat exchanger / draft reducer / creosote chamber. Their stove is going on about 20 years and is due for replacement. When it's done, I want to take that bad boy outside and induce a chimney fire in that top chamber as it has got to be completely loaded.
Can't compare it to an actual single barrel stove, but I'd assume the singles would draft better but that is just a guess.
I actually have a buddy w/ an old Blaze King where he placed a barrel on top of the stove and then has the chimney pipe attached to that. Not saying it's a good idea, just that I've seen it done.
pen
thanks for moving it!
also thats a great idea to use it as a smoker too!
maybe i will get the dual kit. need some heat now.. then work on the water heater tank stove for fun later.
the legs are so short on the stove kit tho. i might have to make a hearth out of cement blocks to get them stoves up higher since there might be some gas fumes in the pole barn at times. dont really want to make it unstable tho. would like it 2 feet off the ground.
Just change your diet. :coolsmirk:
anyone burn mostly slab wood? thinking of getting a few cords of it
Member karl does. Shoot him a PM.
I made a double barrel stove for a shop I had.
I wouldn't bother with a water heater, too thin.
actually the water heater tanks are allot thicker then the 55 gal barrels.
I used resin barrels, with clamp on tops.
For regular oil barrels you are likely correct.
what are these barrels yoru tlaking about? maybe i need to locate some of them, because all i have is old oil barrels. they dont seem to thick.
The ones I used had clamp on lids, and were used to hold resins used in manufacturing. They are easily twice as thick ia oil drums.
Are there any good sized boatyards near you?
Heated with a double barrel for years. Used a truck fuel tank, cut the end off, welded a flat plate with installed door, used regular 55 gal drum for upper. Knew a guy who had a auto repair shop and heated with double barrel for years..
ya 2 ports, them are good sized for sure!
heres my load of slab, gonna get another one soon too!
fuel tank is a great idea! heck i got a beer keg, its alum tho. that would be a neat little stove if you could keep the temp down, i dont know what temp alum melts at.
Aluminum melts at 1200F, far too low for a wood stove.
A lot of kegs are stainless steel though.
For that slab wood, a barrel stove wood be good though, because of the length.
well i placed the order last thursday for the stove kit thru ace! just got the single kit for now, can add the double on later if i like i guess.. cant wait for it to arrive, think im just gonna use one of my fuel oil barrels i got laying around for now, and hunt out the infamous thicker barrel later on in time.
should be 10 days tell the kit gets in. still need to make a crappy door on the front of my pole barn to help with the heat retention some.
kits in, gotta go pick it up. what you guys think about using all single wall black pipe for the chimney for a non heated pole barn? i would go out the side wall at a angle with a oval i cut in the metal siding. or maybe out a window.
It will work better if you go straight up.
ya straight up would be best. but then id have to worry about trying to figure out how to seal around single wall pipe going thru the pole barn roof. (its metal sided and roofed)
just seems easier to go at a 45 then maybe straight up the front side of the barn with all single wall stove pipe.
I have a book on wood burning from the 70's that talks about this style chimney. Even back then they only recommended it if it were in something that were to be used for a weekend, once or twice a year and disassembled in between each use.
Lay a block chimney if you need to save a buck. They aren't hard. Or shop craigslist for some used SS chimney
pen
ya block in a earthquake state aint gonna happen with me. anyhow i will probably try it out and post the results. will just be a once in a thing tell i find more class a maybe, i dont think class a will matter much other then clearances since the building is aywhere from -15 (today) to what ever temperature the outdoors ususally is.
Earthquake smearthquake, I am supposedly in an "earthquake state" too and I think it is a load of crap. I put it right up there with global warming.
Looks like we are twins here from your last pic. This is from the spruce beetle kill out of Haines Junction.
I can get some wicked burn times out of it as you can pack the stove absolutely full and I mean full. Did I say full. You can pack it full. ;-) I wouldn't do this with my old secondary tube burner unit though.
Cheers.
  • double barrel single barrel or water heater tank stove?
Put a regular metalbestus or whatever all fuel roof flange with a lenght or two (whatever you need) above the roof.
Run from the stove straight up to the roof flange with single wall. That is the cheapest, best working system and meets the codes and saftey requirements.
Your entire inside run is just black stovepipe, you only have to buy two or three components of the expensive stuff.
Especialy since you don't have the second barrel, the long length of single wall pipe will radiate heat inside the building instead of outside.
oh boy! another slabber! had the nc30 up to 900F this last weekend when i packed it with slab, gotta be careful with that stuff! :) best to pack slab with a round i thinkin!
i got one small 3 foot section of class a metalestos now, so maybe i will get another, not sure how i will secure it to the metal pole barn roof tho, sure dont wanna buy a rood support kit.
