Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
As long as you are getting stove cement, you might want to consider picking up a new gasket. Chip out the old stove cement with a small chisel, wire brush the channel, cement in the new gasket and you'll be good for years.
Thanks guys. I do plan on just getting a new gasket and then cement it in, but my local stove store didnt have gasket cement in a small tube (only large) so I just went with this stuff from Rutland called Hi Temp Gasket Adhesive. Probably not as good, but this is really just a temporary fix so i can keep using the stove until i get the new gasket and cement.
I like the Rutland the best. Currs real fast and wire brush takes it out easy. Never seen the need to use it though if you have a groove. Only ever glued on the ones that go on flat surfaces.
