I agree. I would connect a 2-wire thermostat wire to each of the three zone thermostats or to the zone controllers, splice together with a 2-wire cable that will connect to the Thermguard, where the controllers are would be the easiest. The Thermguard will start and stop circulation on all three zones. The Thermguard is actually just a timer that is programmed for time off as well as time on.kast said:I believe there is a way to hook this up at the furnace so you can use just one.
wil said:I agree. I would connect a 2-wire thermostat wire to each of the three zone thermostats or to the zone controllers, splice together with a 2-wire cable that will connect to the Thermguard, where the controllers are would be the easiest. The Thermguard will start and stop circulation on all three zones. The Thermguard is actually just a timer that is programmed for time off as well as time on.kast said:I believe there is a way to hook this up at the furnace so you can use just one.
Dr_Drum said:Bridgerman, if you have a single circulator system with Taco control valves, is it possible to have a single Thermogard just drive the circ pump independent of the other Tstats, as if it were just another zone, but either jumper additional wires to the Taco valves (from the transformer already there) or manually override the valves using the open/close lever on the side of each valve, leaving them in an open state? This sounds like it would work without any added components, but I'd appreciate your advise. If the Thermogard was wired (jumpered) and had the control valve in an open state, and then the Tstat called for heat would it double the line voltage to the valve solenoid, or would it do nothing?
Thanks, Mike -
I guess I would have to look at the wiring for a Taco controller. Is there a connection that is actuated by 24VAC that will activate all the zone valves in parallel? That sounds a little weird since there is no use for such a thing in normal operation mode. If there is not, you would have to do the relay closure as I described above, or buy a ThermGuard for each zone.Dr_Drum said:wil said:I agree. I would connect a 2-wire thermostat wire to each of the three zone thermostats or to the zone controllers, splice together with a 2-wire cable that will connect to the Thermguard, where the controllers are would be the easiest. The Thermguard will start and stop circulation on all three zones. The Thermguard is actually just a timer that is programmed for time off as well as time on.kast said:I believe there is a way to hook this up at the furnace so you can use just one.
Basically what he said, (I'm catching up with you guys) I think I just want to install it in parallel so that it is invisible to the normal system operation, but when the Thermgard would close it's contacts, it would energize and open all the Taco's and start the circulator, just as if all the Tstats called for heat at the same time. I guess I'd have to look at the wiring more. I don't want to mess with the manual override levers. This is a really simple furnace installation and the transformer junction box is located about 3 feet away from the circulator and the Taco valves. No need to run wires to the Tstats as they come to this junction box. I could install the Thermgard right at the box. It shouldn't matter if the Thermgards contacts are closed or not when a Tstat closes, a closed circuit is a closed circuit, right? Only problem is if the Thermgard is closed when a specific Tstat calls for heat, the whole house gets heat until the Thermgard timer opens.
Sound right?
Mike -
