does it really
chrisasst
1,289
cortland ny
does a dirty blower motor fan really effect anything besides the speed of air blowing out?
Besides not being able to move enough air to warm your house it can also allow your stove to overheat to the point a high temperature shut down will occur.
In addition to that little issue it can also cause the motor on the blower to fail earlier.
I have seen a few get unbalanced and damage the impeller wheel once the fan went into high speed. Made a heck of a rachet! I saw another get jammed with lint balls and burn the motor up, What a nasty smell that was. The one that stands out the most is here:
https://www.hearth.com/econtent/index.php/forums/viewthread/50579/
Stuck motor(lack of lube) over heats the stove. Tech wants to throw a control board at it for $300. All it was, was overheated and the snap disk needed to be reset. Eventually we had to swap out the fan with a new one. Still saved him lots a cash!
If you keep it clean and lubed it will last longer. Same goes for the Combustion motor.
I'd guess that the glass would get dirtier as I think the excess combustion air from a pelletstove [other than europa]is heatwaste.
also a bad motor will draw more amps and cost you more for electricity, or eventually pop your breaker if it draws too many amps for your breaker.
