Just picked up a jug of generic bar oil at HD, then I got to thinking, "What would the boys at Hearth.com think about that?
Does it matter what kind of bar oil you use?
peakbagger said:I have noticed that when the seasons change, the local logging store stocks the right viscosity. Its generally hit or miss at chain stores.
It does get warmed by engine heat at least to some degree but if you store the saw in sub-zero temps it could take a while. I switch to a medium weight in Winter. The heavy weight oil won't even pour. Back when I was cutting professionally and going through lots of oil, I would buy only the heavy Summer weight oil and thin it out as needed with kerosene.Needshave said:I never thought of changing viscosity for the tempeture. I figured the heat from the saw would warm the oil.
LLigetfa said:Back when I was cutting professionally and going through lots of oil, I would buy only the heavy Summer weight oil and thin it out as needed with kerosene.
As for brand, I never had any loyalty.
smokinjay said:If your buying right if or when you ever sale you will find that you paid very litte for the use of your equiment......For example my 361 I used for 13 months I had 500.00 in it +39.00 for the case 3-chains paid for one 15.00 bucks...total investmet 554.00 it sold for 505.00 + 60 shipping it cost me 25.00 to ship it so after 13 months of use it cost me and 50 to ebay 10.00 to use this saw NOT BAD no matter how you look at it....I have done this many of times with stihls.
Battenkiller said:Has anyone tried the biodegradable bar and chain oils? I know animal fats have a pretty good "cling" to them, and therefore might get flung off less from the moving chain. I'd also feel better about the whole thing if I was doing my part to keep petroleum-based oils out of the ground water.
Are you talking regular motor oil? Can that be used for bar oil?smokinjay said:30 weight it will be fine...
chris-mcpherson said:Are you talking regular motor oil? Can that be used for bar oil?smokinjay said:30 weight it will be fine...
Best to filter it through your old shorts, or new ones if you want that "used" look.smokinjay said:chris-mcpherson said:Are you talking regular motor oil? Can that be used for bar oil?smokinjay said:30 weight it will be fine...
yes straight 30 weight...And if you can get it used filter it through old blue jeans and or coffee filters.
oldspark said:Best to filter it through your old shorts, or new ones if you want that "used" look.smokinjay said:chris-mcpherson said:Are you talking regular motor oil? Can that be used for bar oil?smokinjay said:30 weight it will be fine...
midwestcoast said:Does anyone know if the regular Husky brand oil is bio-based? Thought I read that it was, but I don't see any mention of it on the bottle. I'd much rather use the bio stuff.
