Warren said:A Castine (400) is likely a MUCH better option for that level of heat output
Drafty said:Warren said:A Castine (400) is likely a MUCH better option for that level of heat output
According to Jotul, the heat output for the 118 is equal to that of the
400.
I replaced my old 118 with a Castine. Suffice it to say, I'd rather
have the old 118. I'm currently considering replacement stoves and I'd
really love to go with the new 118. Unfortunately, there isn't a ton of
feedback from owners of the stove. Also, they don't make the stove with
an enamel finish at this point. MSG, any idea if they're planning on
releasing this stove with an enamel finish?
Warren said:Drafty said:Warren said:A Castine (400) is likely a MUCH better option for that level of heat output
400.
I tried to make that point also about a month ago and someone here (can't remember who...Precaud?) said his experience was that the new 118 was no where the equal of the Castine.
BeGreen said:Not trying to defend one stove or another, but if I remember the conversation right, the conclusion was not that the F400 blew away the new F118, but the F400 did hold a much longer fire. Back when the forum first started someone posted that they could only get about 1 or 2 splits in the new F118 due to blockage by the secondary baffle.
Well in a way it does make sense, MSG. You can't put large-diameter wood into a 118, and since the whole firebox ignites with the new one's air system, long burns are pretty much impossible. No cigar-burns like the old 118. The Castine will take larger chunks which allow for a longer burn time. The guy I know who replaced the new 118 with a Castine is much happier with the latter...MountainStoveGuy said:the firebox is like 26 inches deep in the 118. I think its more designed to put long rounds on top of a coal bed. The firebox size is identical just a differnt orientation. Im not trying to be arugmentative, its just doesnt make any sense that the castine will blow away the 118 when they have the same firebox size
Alaskafire said:I too have a new 118 and am a little disappointed with performance. Are there any modifications for those of us in areas without woodstove regulations that could improve performance (heat output and burn time) ?
FWest said:I have a 118, it heats my home just fine. All I burn is seasoned hardwood. A celing fan helped the most for spreding out the heat. If I load a large, just fitting in the door, half round on top of a good bed of coals it will burn all night and leave the stove @ 150F in the AM. My $.02
Warren said:FWest said:I have a 118, it heats my home just fine. All I burn is seasoned hardwood. A celing fan helped the most for spreding out the heat. If I load a large, just fitting in the door, half round on top of a good bed of coals it will burn all night and leave the stove @ 150F in the AM. My $.02
How new is yours? Current generation?
