Does anyone know what this is?
ckc0828
6
New Jersey
Does anyone know what this is for? Bought a house and this was inside of my fireplace.
Does anyone know what this is?Does anyone know what this is?
What fireplace is it
That looks elegantly homemade, I assume its some kind of a grate, or perhaps half of an andiron set?
Have you tried using Google Lens? I've used it to identity obscure tools, spare parts etc. If this item is commercially made, and there's a similar image of it anywhere on the internet, Google will probably recognize it.
TE
My guess is an ethanol burner or part of an ethanol burner
Reactions: bholler
Whatever it is, I don't think it's been used for it's intended purpose.
- The legs don't look like they were designed to be legs. They look more like those wall brackets you use to support shelving, but bent at a funny angle
- if it's an ethanol burner, then it's missing some pieces because the ends of the tube are open so any liquid you pour in would run out the ends
- Judging from the smoke stains, looks like someone lit a fire underneath it. Don't know what purpose that would serve, maybe to hang something above the fire??
@gthomas785 Thanks for sharing your comments. This thing was placed inside of the fireplace (instead of a grate) and I couldn't figure out what it is or how it was used. Was tempted to ask the seller but didn't want the trouble of communicating through my agent and her agent. Anyway, I have since bought a grate and will just store this item in the basement and likely never look at it again~
Reactions: gthomas785
Almost looks to me like a chunk of a corner shelving unit. Maybe they chucked it in there to burn wooden shelves out? Definitely doesn't seem to be a part you need or should even have in the fireplace. Is it actually stainless steel? If aluminum, it would melt pretty quick in a 'real' fire.
Reactions: David.Ervin
@Corey you piqued my curiosity, so I snapped a few more photos from different angles. I can see it possibly being part of a shelf unit.
  • Does anyone know what this is?
I'm wondering if this is a home made log prop. You could position logs standing up like a teepee. Help to get air under the logs so they burn hotter? As mentioned before, if it's aluminum it will melt. Steel or iron would hold up.
