Do you use humidifier to on stoves with fan?
garth_2022
40
new york
I am finding my humidity in the living room down to 29% when the forced air from the Hi500/CI2700 has the fan blowing all the time.
I have baseboard heating because I know how forced air heat dries out a home. Now that I am using the stove insert for my heat, I am encountering that humidity issue.
I have a n ultrasonic humidifier I used, until I read that they cause more harm than good with ozone or something else (I don't recall), so I hesitate to use that now.
What are you guys doing?
FWIW, almost any form of heating that raises the interior temp well above the dew point will dry out a home. The question of using the stove is asked many times here. Using a kettle on a wood stove is an inefficient method and often just a trivial source that is not effective. A humidifier will be much more effective.
Reactions: garth_2022
Thanks, and a kettle won't work for a stove insert anyway.
I always laughed when people said put a cup of water on your baseboard heater to add humidity to the room.
