I believe the manual for my englander says not to, but I was wondering.....why?
any advise would be great, Thanks!
lessoil said:I asked about this during our install.
Harmon has a "trap door" that closes after it drops pellets onto the auger.
This door and seals around the auger should prevent fire from getting into the hopper.
not really a sealed system... The slide plate is more there for metering pellets into the augerlessoil said:I asked about this during our install.
wastings said:dose this include all pellet stoves from englander ? my 25-pdv dose not have gasket, nerver has. so if this is the case mike could you send me one ? its only been 15 years this way
THANK YOU MIKE HOLTON! You answered my question. I just wanted to know if I could "refuel" the unit without shutting in down.stoveguy2esw said:ok, here's the official poop on this;
you can open the hopper to check the level of the existing fuel.
you can open the hopper to add fuel as long as you ensure that the hopper lid gasket is kept clear of debris before reclosing.
you should not leave the hopper unlatched and walk off.
you should not overfill the hopper so that the hopper lid cannot be latched to achieve a good seal.
the hopper is sealed for good reason , if the hopper is not sealed and a power outage or other "immediate shutdown" occurs the sealed hopper prevents the flow of smoke back through the feed system into the hopper and possibly into the home as the unit smoulders out. anyone who has seen what the burn chamber looks like when the stove shuts down would understand , smouldering pellets can make a heavy dense smoke quickly when they are going out without a forced draft, . leaving a hopper unlatched creates a path for this , and the opening would be above the smoking pile of pellets , almost like a chimney.you dont want this in your home.
woodsman23 said:It is fine to open it and fill it not even an issue. Who in their right mind is going to shut down the stove to fill it up..........
j00fek said:if you have to fill it @2am, do you shut it off?
BubbRubb said:woodsman23 said:It is fine to open it and fill it not even an issue. Who in their right mind is going to shut down the stove to fill it up..........
I spotted a few candidates while waiting on my wife last night in the WalMart parking lot
