My mom can't get off oil but busted loose from "the contract". She has a buried oil tank. Now that she will be responsible for determining oil levels, I'm asking the simple question above. Any feedback would be appreciated.
I've seen pnumatic ones that are calibrated to read based on the "pressure" in the bottom of the tank. I think there are sonar based gauges as well, but those are costly.
I'd use a dipstick as well. Be sure it's insured against leakage and know the construction and age of the tank.
You need to know the tank dimensions and then mark up a stick for that tank size. You prolly can find the inches=gals. info on the web. to mark up your stick. Figuring out the dia is the easy part. Maybe someone here has a trick to find the legnth.
I have the same thing on my indoor tank. Always worked well for me. No experience with the underground one. It looks like the idea is that you put the sensor on the top of the tank and then run the wire to the house or some other nearby structure to attach the transmitter to. Then the receiver goes in the house. Is $229 installed?
