Hi folks,
I recently tore out a wood burning manufactured fireplace in a multi-story condo building. It was a corner unit and my plan is to just close up the wall behind where it was so the room is rectangular again. Once I ripped out the drywall that was behind the unit I opened up access to a huge chase where the flue pipe for my unit plus an additional flue pipe for a unit on a floor below me is. I am wanting to be sure that I seal it up correctly and safe. I have not been able to find any codes on the ICC website in the IBC or the mechanical building code book stating that I need to use type x drywall, double layers, etc... The flue pipe had a tag right on it stating to keep combustible materials at least 1" away. The chase wall had several layers of drywall (one of them 1" thick which I have never seen) originally. I don't know why.
I've attached some pics.
Does anyone know for sure or have any ideas if I need to do a layer of fire rated drywall on the chase side, with fire rated drywall on the room side as well? Or can I just insulate and use standard drywall on the inside and call it a day?
Any help would be appreciated. Also, the location is in WV and in a very rural area where there are no local inspections done and to my knowledge no amendments/county specific codes. They just follow the IBC/IRC, etc...
Thanks,
Todd![Do I need to use fire rated drywall on the inside of this chase? Do I need to use fire rated drywall on the inside of this chase?](https://www.hearth.com/talk/data/attachments/294/294773-382907a1fd582fed0f2492fab71fe840.jpg)
Thanks,
Todd
