I have a wood insert that I installed 2 years ago with a new 6" SS liner. The chimney is on the outside of the home, has 3 flues, and made of stone. The liner terminates on top of the center flu. On the top of the chimmey there are stone piers which on top sits a 1/8 steel chimney cap to cover all 3 flues. Its about 30 x 60. My issue is the smoke condenses on the bottom of the steel chimney cap and runs down the chimney and of course eventually on to my shingles. My plan is to extend the liner to sit on top of the steel cap. I already cut a hole in the metal but I am not sure if I should use the left over liner or buy an 18" length of insulated chimney pipe? My fear is that if I use the liner in the 18" or so the smoke is above the roof line since the pipe is not insulated the smoke will condense inside the pipe as it cools and I will end up with more creosote in the pipe. Do they make an adapter to connect SS liner with insulated pipe?
