Do I need draft induced kit?
08brute
89
South Dakota
I have the US Stove Company 1600 model and I currently run with a manual draft damper. My draft is pretty good and I do not have many problems keeping a fire lit or smoke coming back at me. My questions is would a auto draft induced fan benefit me? Would it help my fires burn more efficiently and for longer? Is this a must have?
Thanks in advance!
Thanks in advance!
Probably not... An inducer is mostly needed for those folks that have problems with chimneys that don't want to draft well (especially when cold) or that puff back when loading or getting a fire going. If you aren't having a problem, I would not expect you to get much benefit from an inducer. If anything some folks even go the other way and add a barometric damper to REDUCE the draft going through the stove by supplying an alternate air source.
Gooserider
