Do i need a block off plate
ohio woodburner
408
NW Ohio
Neither my insert or my SS liner instructions mention a block off plate. Do i need one or should i just go with out it?
I posted in the other post of yours that I would to help keep the heat in and the smell out lol
If you have an exterior chimney, you will lose heat out of it, and you need a block off (with rockwool on top) OR stuffed in insulation (rockwool, not pink fiberglass)
With a full liner, metal block off plate seems to be a 'peace of mind issue' for folks around here--depends on your mind--do you need more peace?
I have a nice metal block-off, but I'm running a direct connect.
even internal brick or stone chimney will rob lots of heat. the more you grt in to the room and not up the chimney (I did not say flue becase of the full liner).it be like having an open window IMO
When we install a full liner (The only way we will install a wood burning insert) we jam the heck out of the damper area with rock wool. We also pack the top of the liner right under the top plate with rock wool.
