do bigger stoves need more draft?
pro5oh
150
downeast Maine
Hello again all. Just installed a englander 30 inplace of a VC resolute. I'm not getting enough draft now for this stove, the other was fine. Should I get a smaller stove or buy a draft inducer? Running the 30 wide open the fire dies down with the door shut and has about 350-400 degrees surface temp, got creosote build up in just 3 weeks. Yes wood is dry
Is a draft inducer the same as an outside air kit?
No it is basically a fan that goes in your flue made to create draft its called a ad-1 I think.
Does your stack comply with what is stated in the manual (height, diameter, etc.)? Have you added any 90º bends to the run for this new stove? Is it a stainless or masonry chimney.
I hate to say it, but if you have creosote in 3 weeks, your wood is probably not fully seasoned. It would be difficult to imagine that happening with dry wood.
As for draft, imagine a fire in an outdoor fire pit. Do you imagine that a huge fire that you have to stand way back would take more oxygen than a small fire where you can stand close?
A bigger stove may require more combustion air, but that is not the same as draft requirements. It does sound like a wood issue from what's been posted.
Can you describe the flue on the stove?
