So, I know almost zero about wood burning appliances... But I'm smart enough to realize that there are people that live wood burning appliances and love to share their knowledge, and that's why I'm here...
As with most unknowing people, I have lofty design goals and ideas that will quickly be dashed by reality and expert knowledge..![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
I have an 8x17 'room' (Military comms van 'box') that needs to be heated, and bonus if I could boil water (should be a non-issue). Insulation is 2" of XPS foam, but with 10 windows, hahaha... yeah..
So, I have a spot that's about 2 1/2' wide, 3' deep, and 7' tall, that I want to utilize to fit a stove in.
I have access to as much steel plate in any size that I need/want, and welding materials. I have all the materials, but none of the knowledge (which is why I'm here)
I have seen small/thin wood burning stoves for boats, which is where my idea came from... But I do have quite a few questions.
I would like to fit a smaller size log in there, whereas most of the small wood burning stoves I've seen (for boats) essentially want you to burn what amounts to twigs..
1. How will a log burning vertically vs horizontally impact heat, burn time, etc.? Is there any reason why burning a log vertically would be a bad idea?
2. As far as baffle systems are concerned, would either of these be good?
The prime concern would be to produce as little smoke as possible, with secondary being to retain as much heat as possible and spread it into the area instead of wasting through the exhaust pipe.
3. I already have an air inlet, a 3" pipe hole... which I plan on using with a foot or so of piping, with a flapper valve/flue control in it as means to control air flow. This way all my air will be coming from fresh air outside instead of using air from inside the cabin area. Similarly, I wanted to to use a flue control setup on the exhaust side as well, going straight up, to retain some heat and retard the burn (?). My concern is that by drawing air from the bottom, and exhausting out the top, all my heat will be lost outside through the exhaust vent, instead of being used to heat inside.
4. As mentioned above, I want this to be vertically oriented, so the logs would be placed and burned vertically instead of horizontally.
5. I intend to use 1/4" steel, and use heat brick to line the bottom..
6. Alternatively, I do have head space to run a 'less insulated' exhaust pipe along the length of the interior, at a slight incline, to allow more heat to dissipate inside rather than outside, but I don't know anything about flow calculations, deposit or condensation issues, etc. or if that would even be needed.
Thoughts? Critiques? Ideas?
I'm just at the beginning stages, obviously, but trying to get a better idea, to make sure it's built properly, and not something that's gonna melt after the 4th time I use it, or dump 90% of my heat outside, or burn through a log in 3 minutes.. :D
