I want to share what I have learned from hours of reading forums and watching youtube - an attempt to repay those who laid the groundwork for me.
I have a Suburban Manufacturing Wood Chief / Coal Chief stove insert that has faithfully heated my house(s) since 2006ish. This is been a great stove, 4cf fire box, ash tray, two speed blower with snap disc, and two small windows.
The stove makes good heat but began to bother me with the amount of heat lost up the chimney - there are NO baffles in the stove. Not wanting to continue being wasteful I decided to buy a Quadra Fire in the summer/fall of 2020. Gotta save up for these expensive things! As I read the manual for the new stoves, none of them have ash pans - I don't want to shovel ash from my stove! Seriously, the lack of an ash pan was the straw that broke the camel's back on this new stove idea!
I did a fair amount of reading on retrofitting secondary air to old wood stoves. After some measuring and thinking I took a stab at making my own. All parts came from Lowe's and Tractor Supply.
I used 1" black pipe to make the secondary air hoop around the top of the stove. The air distribution bars are 1/2 black pipe. Air control to the secondaries is by a 5" long tube that I plasma cut the sides out of, then turned the threads out of a 1' on the lathe to make a shutoff valve. I made a "tray" to hold 1.5" thick fire brick baffle on top of the air manifold. There is a 1" drop from the front of the baffle to the rear. The gap between the firebrick and the top of the stove is the same area as my 8" flue liner.
the pictures will probably make a lot more sense than my text.
Final result? I believe I am successful! I get rolling yellow to blue flames across the baffle, once up to temp smoke from the chimney is nearly gone, and this thing is MUCH less hungry than before. I have no problem burning a load through the night. Just yesterday I relight a fire 14 hours after the last load. Stove temps come up to 750 right after loading and settle in around 550-600 (through the top air vent), 450 on the doors.
I watched a bunch of youtube videos, and get the impression that some of them are for show. I occasionally get long yellow jets of fire, but that doesn't last long. Light blue rolling flame across the baffle occasionally lasts for hours!
I had to reseal my doors and make new hinge pins before this thing really started to work. My primary air comes from two hand wheels on the ash pan door, I believe it would be better if my air came from the back of the stove, but that is a modification for another day!
I dont' see a hyperlink button, so here is a link you may need to copy for a short video - really it is a summary of the attached images.
Thanks for the help from those before me.
-Robert
![DIY Secondary Combustion / Air DIY Secondary Combustion / Air](https://www.hearth.com/talk/data/attachments/253/253394-270a6e6504579d1021c27d79cefa497a.jpg)
![DIY Secondary Combustion / Air DIY Secondary Combustion / Air](https://www.hearth.com/talk/data/attachments/253/253395-7beb49ccdce6276fe1dbdafeeb0ef862.jpg)
![DIY Secondary Combustion / Air DIY Secondary Combustion / Air](https://www.hearth.com/talk/data/attachments/253/253396-067543b95ccfa55deea60198d37d7ab7.jpg)
![DIY Secondary Combustion / Air DIY Secondary Combustion / Air](https://www.hearth.com/talk/data/attachments/253/253397-f94acaa3db1f2e11df5906d355514b9f.jpg)
![DIY Secondary Combustion / Air DIY Secondary Combustion / Air](https://www.hearth.com/talk/data/attachments/253/253398-4cd74b2daec8e9e7dac51f4cb8c2d952.jpg)
![DIY Secondary Combustion / Air DIY Secondary Combustion / Air](https://www.hearth.com/talk/data/attachments/253/253399-ba45f318c553ea76689650f2d7e8adcf.jpg)
![DIY Secondary Combustion / Air DIY Secondary Combustion / Air](https://www.hearth.com/talk/data/attachments/253/253400-c539a6817150e5ce87114d71878db827.jpg)
![DIY Secondary Combustion / Air DIY Secondary Combustion / Air](https://www.hearth.com/talk/data/attachments/253/253401-d5df48dbbb02d8f3b263e88693d997ed.jpg)
![DIY Secondary Combustion / Air DIY Secondary Combustion / Air](https://www.hearth.com/talk/data/attachments/253/253402-af57a11611a9aa93fdd54623d897000c.jpg)
![DIY Secondary Combustion / Air DIY Secondary Combustion / Air](https://www.hearth.com/talk/data/attachments/253/253403-e198de79f7f97e834ba2c6a27e1b77c9.jpg)
-Robert
