I am looking for direction and feedback on the construction of an outside storage tank.
TANK..I have access to some salvaged 8"x18"x12' pressure treated timbers. My thoughts were to construct a 3 sided open top tank bolted to the exterior concrete foundation wall of my walkout basement. The interior measurements of the tank will be 9'8"x3'10"x 6'0".
INSULATION..My thoughts were to line the sides and bottom with ??" of insulation. This would provide a smooth surface for a liner. I could also shape the interior prior to adding the insulation if there is any benefit to something other than a rectangular tank with square corners?
LINER..I would need a source for a liner other than EPDM. Is it possible to just take a flat piece of material and fold it into the tank or more advisable to have one custom fabricated and if so, where?
HEAT EXCHANGER..Small diameter copper or PEX? Posibly a DIY site for either or both.
As you can see I don't have much, other then the desire to get back to heating with wood.
I have a "Controlled Combustion System" wood/oil boiler that I purchased in the late 70s. It was fine back then as this old farmhouse didn't have ANY insulation. As I rebuilt and insulated, the boiler became too much on the wood side. I'm thinking a storage tank would be the solution to overheating.
Any help would be appreciated.
Thanks, Stumpuh
Thanks, Stumpuh
