Earlier this fall I started working on replacing my old builder-grade zero clearance fireplace with a new ZC fireplace. This turned into 3 months of work after discovering that the chimney chase was apparently slapped on without any codes or common sense involved.
Skip to the next post if you don't care about the chimney chase construction....
Here is what I started with:
My foot ended up going through the floor due to water damage from a leaking chase cap:
Not pictured: The whole chase was sagging away from the house with a 1" gap between the top of the chase and the rest of the house, and the insulation was turning black from excess heat. There was also almost a square foot of holes going into the attic, which allowed a significant amount of air flow into the house. Fun stuff....
The chase is unsupported from below and hangs above my driveway from the 2nd floor. Instead of using cantilevered joists, whoever built it just toed in some 2x8s to the end joist, which were cracking and sagging under the weight. How this thing didn't fall off the house already is beyond me.
After removing all the water damaged wood I welded some heavy duty steel braces to help hold it up.
I then pulled the chase back into place with some threaded rods to close the gap. Added lots of lag bolts to keep it in place.
After insulating the side walls, I also added 3/4" OSB and tied that into the house to add a significant amount of sheer strength to further support it.
With the 15' minimum chimney length, I would have had 6.5' of chimney sticking out of the top. I was concerned about poor drafting due to my high altitude (7400') and decided to extend the chase another 3.75'.
I was originally planning on just leaving the existing siding up, but discovered that the "builder" had skipped adding any house wrap or tar paper, so water was almost certainly getting in and just drying into the house. Time to rip it all off and start that over.
I had already ordered steel paneling for the extension, and decided to installing LP Smartside where I ripped off the old siding. I am planning on replacing the roof with a black standing seam roof next year, so the metal paneling should match well.
I then insulated everything and installed 5/8 fire drywall. Local codes required it, and IIRC the chimney required it as well. Even if not required, it seemed like a good practice compared to paper backed insulation hanging in there. The steel at the top is just some flashing I had left over and was not required.
Even with all the extra support, I wanted to keep the 500lb fireplace weight off the chase. I used 2" angle steel bars to support the stand from below and lag bolted them to the joists.
I had the entire thing measured out and designed in CAD. Made it much easier to confirm I had proper clearances, etc.
I am certainly no pro and most of my time was spent reading and planning, so I'd be happy to take any pros advice on anything I should have done differently.
