Decided to tackle this prior to cold weather this year. Recently cleaned the chimney and hated the busted up crown. No good companies I can find close, so decided to do it myself.
Starting point:
![DIY Chimney Crown DIY Chimney Crown](https://www.hearth.com/talk/data/attachments/321/321167-f5d18201e43175da5a3e0740d1475d52.jpg)
Removed mortar and top layer of brick to allow for a thicker crown and flue tile exposure:
![DIY Chimney Crown DIY Chimney Crown](https://www.hearth.com/talk/data/attachments/321/321171-f260c9c00ebbe4b77349d665a6a15a9e.jpg)
Day 1 Progress:
![DIY Chimney Crown DIY Chimney Crown](https://www.hearth.com/talk/data/attachments/321/321173-91953a373146cddd1aa1e29e4921c188.jpg)
Adding some mortar to reinforce my new top layer and to better support crown support structure:
![DIY Chimney Crown DIY Chimney Crown](https://www.hearth.com/talk/data/attachments/321/321174-deb8c8ff1d399b883c0822f17a2ef678.jpg)
My plan is to use floating angle iron / cement board to create the base for the crown. I'll use 2x6's around the 2x4's for the form and leave a couple inches of flue tile exposed on top. I will provide room for expansion around the tile.
I might use a line of caulk on the 2x4's for my drip edge, or just come back after with a grinder and notch under the 1.5" overhang.
Starting point:
Day 1 Progress:
