There are a few different piping configurations to divert some of the hot boiler supply water to storage while feeding the heating zones. When a small zone calls for heat, this can be important so as not to idle the boiler.
When using the Simplest Pressurized Storage System Design, I'm thinking of replacing the load circulator with the new Taco Delta T variable speed pump.
The pump speed will throttle with the delta T, when the pump slows, more hot water to storage. When the pump speeds up as in more of a heating demand less hot water to storage and more to the zone. This should all happen automatically, as there would be no restriction to the pressurized storage tank.
This would really simplify my system as I'm using two zone valves, a normally open and a normally closed with a ranco aquastat to accomplish this now.
I spoke to a tech @ Bio-heat and he thinks this would work rather well.
Any opinions?
Any opinions?
