Disease ? Bugs?
Lloyd the redneck
291
Western mn
So I have a few trees on my property that leak. Looks like someone burned them but now I found out that's not the case. The goo that comes out smells aweful and my dang dogs rub in it. Anyways. It looks like little white worms trying to get into the tree. I do not know the species of tree. Here's some pictures , I'm supposing I need to cut them all down. Some guidance would be much appreciated. [Hearth.com] Disease ? Bugs?[Hearth.com] Disease ? Bugs?[Hearth.com] Disease ? Bugs?[Hearth.com] Disease ? Bugs?
Kind of normal for elm (common on Siberian elm) to have some amount of wet wood, or slime flux:
http://extension.psu.edu/pests/plant-diseases/all-fact-sheets/wetwood-or-slime-flux
http://ipm.illinois.edu/diseases/series600/rpd656/
http://shadetreeexpert.com/tree-diseases/
It's a bacterial infection with anaerobic conditions in wounded portions of a tree. The lack of oxygen holds decay in check. If attempts are made to change anaerobic conditions that exist in tree (e.g. drilling drain tubes), then it will cause aerobic conditions that are conducive for fungal wood decay. While unsightly and sometimes stinky, most arborists don't consider it a major problem; however, there are some willing to sell a "fix" for it .
Fell, cut into lengths that will fit into your stove, split, stack in the sun and wind for at least two years, then enjoy the "free" heat that those suckers give off. No more small white worms, smell, or other problems. Feel free to replant future fuel close-by.
Reactions: Tech Guru
I personally don't think that they are any diseases, I have seen trees leaking before. But to be honest they were very small leaks and stopped itself.
I think you should wait some more and get an expert advice before cutting it down.
The only reason I ask is cause the wife is determined we need to cut them down. I don't like to cut them down. Unless nessicary.
Listen to your wife. I hear here on Hearth it's the only way to a happy life. Plus, who wants all those puss-oozing trees hanging around.
