I am building a new home, and a gas stove with direct vent will be on an interior wall. A few stoves I am considering have rear vent as an option, and I thought it would be clean to run the pipe out of the back horizontally a few feet into a chase where a 90 degree elbow changes to 10 foot vertical run and through the roof.
Someone at a stove shop said "you have to go vertically up at least 24" before transitioning to horizontal. Then through the wall, and the elbow to change to vertical."
In looking at stove manuals, I see the snorkel requirement for "through the wall" installations, that provides said vertical rise outside in other to get proper draft.
My question is, is there a general rule that for direct venting gas stoves in other than a through the wall scenario, if a horizontal offset is needed, that horizontal offset must occur at least 24" above the stove? Thank you in advance.
