Looked up this prior thread, and I'm having almost the exact, same problem.
www.hearth.com
I have a Majestic (now "Vermont Castings") direct vent propane fireplace, installed and as far as I knew, working in 2017. I noticed over the past several years that the front ports weren't lighting, and figured it was because the rock wool "embers" had been improperly installed (by yours truly), covering one or more of the ports. I was going to get around to opening up the unit, cleaning it out, and fixing the problem, and "someday" was July 2020. After I'd removed the rock wool (and fake logs, and ornamental lava rocks), blew out the burner from the top (as much as I could, applying air pressure to each and every port, it still wouldn't light. Disappointed, would be an understatement. Shocked would be closer to my emotion.
So, through the wonderful world of the "interwebs", I found out about proper gas line pressure, bought a manometer, and sure enough, low gas pressure. The appliance plate states 11 inches at inlet, 10-10.5 inches at outlet. I was seeing about 9.5 inches at inlet. Went outside, and discovered the house second stage regulator had been factory set at 10 inches, whereas should have been at 11-13 inches. I bumped it to 12 inches (more is always better, right?)![cheese ==c ==c](/talk/styles/default/xenforo/smileys/cheese.gif)
Slapped everything back together, tested pressure at appliance inlet, 11 inches, tested at outlet, 10.5 inches, and we're in business - all fixed. Grabbed a beer, patted myself on the back, fired that baby up to see the rewards of all my hard work, and ...... no change.
(Ever seen a grown man cry into his beer? Yeah, that was the emotion I felt then.) So, I put my best problem solving skills to work, which meant grabbing more beer, and closing everything back up to "think about it" and come back with a better solution. (Hey, tactical retreat IS one way of problem solving.
So, after enough time passed, (and my wife starting to nag about "are you ever going to finish that fireplace?"), I pulled the appliance apart, closed the fully open Venturi shutter on the burner, and applied 120 PSI of air pressure through the Venturi for ... a while ... in an attempt to clean out anything that might be blocking the ports. I haven't yet reassembled and tested the unit yet (that is NOT a trivial undertaking; lots of screws in tight places), but looking at that Venturi got me to thinking. (Note: The closest thing to a specification I could find said that propane Venturi's were supposed to be 1/2" open, and mine at full open (factory default) was about 5/8", so I did tweak that shut just a bit, as shown in the picture.)
Here's my first question: 1/2 PSI equals 14 inches of water, so gas is flowing through that tube at less than 1/2 PSI. That Venturi opening (there's one on both sides, which is probably standard) is one huge opening for heavier than air gas to flow through. I've never thought about this before (i.e. in regards to BBQ venturi's, etc.), but is 1/2 PSI enough velocity to push that gas through the tube (picking up air from the open shutter in the process), without dumping propane OUT of that hole? I mean, here I am adjusting the second stage regulator to ensure I have an extra 1-2 inches of water pressure, while I've got this gapping hole in the Venturi shutter ... just doesn't make sense.
So, back to the originally referenced thread. The OP said he tried DAKSY's recommendation, and it solved his problem. I've tried to push a q-tip inside both the supply hole of the Venturi (can't; obviously it has a device that reduces that gas flow, because the hole is blocked by copper) and the gas supply line. I found no obstructions there. When I blew out the burner via that Venturi opening, nothing obvious (like a cloud of dust) shot out of any of the burner ports, that I could see.
One last thing I tried was to check the burner (as installed) for level. It's pretty close to dead on level. I would have expected a slightly downward tilt (i.e. towards the front), since propane flows in course with gravity.
So, before I reassemble and test this thing, does anyone have any other suggestions? I'm not optimistic that this "disassembly & blow out" process did anything to improve the situation, and I'm out of ideas.
To recap:
Heatilator GNDC33 - flame size too low
Hello all, My first gas FP post. We moved into a home that has two direct vent propane Heatilator GNDC33 fireplaces. Initially both had pilot and ignition issues that were tracked down to bad thermocouplers and thermopile sensors. Both entire pilot assemblies were replaced and that resolved...
![www.hearth.com](https://www.hearth.com/talk/styles/hearth/hearth/hearth-logo.png)
![embarrassed ;em ;em](/talk/styles/default/xenforo/smileys/embarrassed.gif)
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
To recap:
- See attached pictures of the burner, the Venturi, and burner when lit. The area marked in red are the problem port areas.
- Originally, the area in the burner picture marked in read, upper middle of the burner, failed to communicate flames to the other ports, as well. I did the unthinkable, and took the next sized larger drill bit and made those ports from back to front just a tiny bit larger, i.e. barely shaved any metal at all. Now they flare a bit, but the flames travel to the forward ports, but not completely.
- Checked gas pressure, and ensured it's at spec.
- Checked and cleaned each individual port with a properly sized drill bit.
- Disassembled and blew out burner from Venturi.
- Checked gas supply line that connects at Venturi for debis.
- Note: All ports supply propane. I can easily light every one with a butane lighter.
- If this doesn't work after reassembly, I'm gonna need a whole lot more beer.
