If you got hit in the power outages in new england & just bought a generator, You need to know that it is not designed or intented for continious oppertaion.
If the engine is not equipped with an automotive type screw on oil filter then chances are you have a splash oiling system & are looking at a 2 or 3 week engine life span on a new engine
under continious opperation.
If you want your generator's engine to outlast the power outage, only run it for 3 hours & let it cool off for 20 or 30 minutes.
Engine Oil, Grade Of,----- Is Determined by cold engine external temp. This is the outside temp
when you start your cold generator engine.
5-W-30 is what you should be using for winter time.
5w30 is rated for 50 below in sinthetic but only 10 below 5w30 in dinosaur oil.
10w30 is rated for(+45* to +10 *) 10 deg above or higher but may cause engine failure at 5 deg F above zero.
SAE 30 is rated +99 deg to +45 deg and could cause engine failure at 30 deg above zero.
at 30 deg above zero, sae 30 has the consistancy of vasoline jelly & can not lubricate your engine.
at plus 5 deg F, SAE10w 30 has the consistancy of vasoline jelly & cannot lubricate your engine.
at zero deg, 5w30 dinosaur oil has the consistancy of vasoline jelly and cannot lubricate your engine.
at minus 50 deg below zero,sae5w30 Sinthetic has the consistancy of vasoline & can no longer lubricate your engine.
Once the engine has run for 15 minutes, the oil will warm up & lubricate but the wrong grade of oil means that for the first 15 minutes of opperation your engine is essentially running without lubrication & subject to advanced wear & premature failure.
Two types of engine oiling systems.
If you paid under $600.oo for your generator, chances are good that you have a splash oiling system without a positive pressure oil pump. To find out, look for a spin off automotive oil filter on your engine.
If you have a spin off auto type oil filter,you have positive pressure oil pump. If you dont have an oil filter, you are splash oiled.
Splash oiled relies on changes of engine rpm & the proper grade of oil for the outside temps
for adiquate oiling of your engine. This type of engine is designed to run for 2 or 3 hours & then a 30 minute cool down period and may use oil faster than you think. check the oil level every refill of the gasoline tank, usually after about 3 or 4 hours of run time.
These are your cheaper briggs & stratton or tecumpsha engines in the 3 to 6.5 hp range , mounted on your cheaper generators.
They are intended for intermitant running of power tools & lights on the job site & not for 24 /7 usage.
The engines with the positive pressure oil pumps & filters are a better grade, more able to withstand a bit harder usage but are still intended for intermitant usage, designed to run 4 or 5 hours & then a 30 minute cool off.
You can run them for longer but I can't say that you will get maximum lifespan from the engine.
I do know that if you try to run them for 24/7 you will be replacing the engine within 40 days.
I remember back 2004 0r2005, when we had a power outage that lasted for some people over a month, that generator engines started burning out within two weeks, some made it to 3 weeks & others to 4 weeks, depending upon how hard their owners abused & missused
them, so a warning to the wise.
Here I have spelled out the causes of premature engine catastrific engine failure & have told you how to avoid it.
So see what happens to your engine if you dont believe me; and read your owners manuel.
Oh never mind I'm too sleepy to worry about it
> :-S
and according to the manual it requires a quart of 5w-30 motor oil with an API rating of SF-SG-SH or SH/CD. So, I checked around at more than a few places while out and about and wasn't able to find oil with the right API rating(s). So, not knowing any better, I wondered if I could substitute my oil with another API rating and decided to do my homework and learn exactly what this API was all about and I found this "The Engine Oil Bible" (link below) which gave me the answer.
