Hello everybody,
I'm having a hard time getting all of my lower section of terracotta tile out and would appreciate some advice. I've been at it about a total of a few hours of spinning across several sessions on the roof. I have prokleen/button-lok steel rods and a double square tile breaker. I had this vision that this spinning setup and flue tile would be similar to terracotta pots (when you look at them the wrong way). I am very mistaken. Picture attached.
I read through this post. I don't think mine is that tightly mortared in place but there is definitely mortar in there. https://www.hearth.com/talk/threads/old-tile-flue-appears-to-be-mortared-in-now-what.181896/
Almost one entire side of the column is gone. Seems like there is supporting brick flush with the interior dimension so I'll need to bust at least one lower side of brick too. I kept descending with the weaker wall because I didn't want to damage the brick trying to get the other 3 sides. I may be able to get away with one long side out and drag my liner through (olympia hybrid flex 304 pre-insulated, about 7.5" OD, and I did elect to get a nose pulling cone, thank god). I believe the lower section is 8x12 OD? It's 12x12 up top - have no idea why they made it smaller for the last section. I've even tried sledging with a 10-foot galvalized pipe on top edges of the column - doesn't budge. The tile breaker does more than the pipe so far.
This is my least favorite part of this project.
Thanks,
G
![Difficulty breaking lower flue tile Difficulty breaking lower flue tile](https://www.hearth.com/talk/data/attachments/287/287612-ba2e742651ae5babce416bda389a2042.jpg)
Thanks,
G
