Didn't know PE had new models out...
Hogwildz
Links to the 2.5 insert, 1.6 insert and the 1.6 free standing
(broken link removed to http://pacificenergy.net/products/wood/stoves/neo-16/)
(broken link removed to http://pacificenergy.net/products/wood/inserts/neo-16-insert/)
(broken link removed to http://pacificenergy.net/products/wood/inserts/neo-25-insert/)
Heh ..........That T5 insert looks like it was dipped in Hershey chocolate
I was thinking something similar, but it wasn't chocolate.....
Reactions: alforit and loon
Hogs, you should stop by more often. Been featuring the new PE models for weeks.
The Neo 2.5 won't be available any time soon, I'm told. Here's links to more photos, pricing, install specs, etc for the other models mentioned:
Neo 1.6: (broken link removed to http://www.chimneysweeponline.com/pacneo16.htm)
Neo 1.6 Insert: (broken link removed to http://www.chimneysweeponline.com/pacneo16ins.htm)
Alderlea T5 Inserts: (broken link removed to http://www.chimneysweeponline.com/pact5ins.htm)
Close-up of PE's Brown Porcelain Finish: (broken link removed to http://www.chimneysweeponline.com/bigaldert5brn.htm)
Tom and I talked about the new stoves a couple months back.He told me that the Neos are entirely "new" stoves with new in-between sized fireboxes.
Alderlea T5 in white enamel. Gorgeous.
[Hearth.com] Didn't know PE had new models out...
Reactions: loon
I think I will send a 30-NC out and have it chromed.
Question about the T5's firebox size (2.1 cu. ft.) and heating capacity. For folks already with one, can you do 2,000 sq. ft.?
If the place was very well insulated, with normal height ceilings and an open floor plan, in a milder climate, maybe. But 2000 sq ft is pushing into the T6 territory for the average old barn.
You're going to want to try and grind off all the weld spatter first. Else the chrome will really draw attention to it.
You got spatter?
Reactions: Dix
