Did this pellet stove shrink?
Don2222
9,151
Salem NH
Hello
Stoves were manufactured by Danson's Pelpro probably the Cheap Charlie line by the model numbers but they both show the same model numbers??
Maybe there is a difference between
CC1 and CCGB1 - anyone know?
See pics below
Click to enlarge
Pic 1 -shows both Danson's Pellet stoves
Pic 2 - is tag on back of the larger stove on the left serial 5899 -- 32" tall x 26" wide x24" deep with an Accutron III
Pic 3 - is the tag of the smaller stove on the right serial # 7437 -- 28-1/2" tall x 21" wide x 22" deep with an Accutron II[
  • Did this pellet stove shrink?
Hello
It looks like they use the same label for 6 different variants (but forgot to indicate which version each one is).
Reactions: Don2222
Told you not to leave it out in the rain
so it wouldn't shrink !!!
Reactions: WoodyIsGoody
Hello
Many times the dimensions are listed with the specs for each model stove. Also as the model # goes up the stove gets larger in the case of the Pelpro
CC1 has the dimensions of my large stove on some of these spec sheets which makes this issue more puzzling? I believe CC1 2 and 3 are generic model #s given to distinguish the size talk about a stove in respect to it's size since most other parts are the same!
I found the dimensions for the large stove but not the small stove?
Glow Boy -- see pic 2 is the larger size dimensions
The larger stove with large fire door window may be the CCGB1 which is the Same size as the
Glow Boy Home Heater 120
Or same size as the
Pelpro Heater 120 -- see pic 1 is the larger size dimensions
CC1 -- CC Franklin 120 or HCF120
Also Edison JR -- see pic 3 is the larger size
Also the Pelpro HHPP2bd is the larger stove!
http://pdfstream.manualsonline.com/9/91d48964-8eb1-4249-8c21-0cc06154188e.pdf
The smaller stove does have the Glow Boy models along with the generic models
I do not see the smaller stove dimensions anywhere?
So What model is the smaller stove?
Can anyone find the dimensions of the smaller Glow Boy stove?
