I have been running my recently aquired stove on high settings and can run the stove on high with the damper fully closed. auger pot turned up and the combustion fan turned down. Burns great with lots of heat.
I am now realizing the low setting is the more touchy range to dial in.
I would like to try and have a low heat setting which has a pellet consumption rate as low as possible.
I have just started and was wondering if anyone had any suggestions or what a I need to look for as indicators a pot setting is not stable.
How low can the flame go?
How much will turning down the pot setting reduce pellet consumption?
I am hoping someone can shorten my trial and error learning curve.
Thank you all again for all the help this forum has helped me with getting started with my pellet stove.
