- Jan 5, 2013
- 3
Hi everyone! I'm new here and have been reading a lot of your posts..... but I'm having a major problem with my Mt Vernon AE Pellet stove. I haven't been able to use it for weeks.... It's freezing here and I've had 2 service guys come out and I honestly don't think they know what the heck they're doing! I've had that stupid "AUGER JAMMED" info come up a billion times and we've cleaned the stove from top to bottom and the first service guy replaced the air pump and then a disk saying each time that was my problem.... then when it read auger jammed again he said it's your mother board! and when I refused to buy that part, my stove was actually turning on....
Of course I would have to disconnect it then plug it back in but it worked for 2 weeks without any problems... then it stopped working again and said auger jammed and we tried to unplug it and plug it back in and we cleaned it out some more but to no avail, so I had a different service guy come out and he checked it and said "check your wiring" then called someone because my stove would start up and you'd see a fire start then the motor would go in reverse and shut down the fire.... So he said I needed a new optical sensor...
So we replaced that today, and it's still doing the same thing..... Fire would start then the motor would go in reverse and shut it all down.... So I tried reading more info on here about this type of stove... my hubby went to check on the thermocoupler which was mentioned a lot on here and we found ours to have a broken piece right where it connects.... now we've had 2 service guys come out and mess with all the wiring and now I have this piece broken?
Any way... hubby tried to plug it in without this outer connector piece and my stove would not turn on ... it would do the autoclean then try to start, but nothing would turn on and the auger jammed would come on. He tried holding it in place cuz the piece looks like it doesn't fit right with the outer connecter being broke off.... So after several attempts, he tested the wire with his power tester and said there's power going to this wire..... But I told him I thought it's probably not working right since we found this wire to have a broken connector..... So he put the connector piece back on and plugged it in.... It wouldn't start up right, then he tried to manually start it by throwing the pellets inside the stove and it started up and turned to ss-low... then said auger jammed..... so now he thinks maybe the motherboard is bad..... Were as I think it's the thermocoupler, since we found it partly broke where the connector connects to the motherboard..... My stove is 3 yrs old and I'm having a hard time believing that the mother board is the problem when it's not that old..... I thought it would
be a problem if other things were issues too... like the autoclean didn't work right, or it just wouldn't turn on at all? Or something else? I honestly don't know..... and I'm desperate to get my heat back on... I'm using portable heaters and they're costing me a fortune as is this stove! So any help or input from all of you wise pellet guys & gals would be most helpful to someone who knows very little about this thing!
Thanks in advance for any help or guidance you could give me!
![Confused :confused: :confused:](/talk/styles/default/xenforo/smileys/confused.gif)
![Er... what? o_O o_O](/talk/styles/default/xenforo/smileys/blank.gif)
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
