DESA Unvented (vent free) universal firebox
LFT
2
Wellston, OK
Hi all,
Newbie here. Bought a 1600 ft2 retirement home recently with a builder's grade Desa model B36L firebox/place with 4" outside combustion air ducted into the side of the unit that is about 10 years old with a 15'- 8" double wall flue in chase. I'm looking at removing this existing firebox and installing a new fireplace or insert. The ones I've looked at heat appr. 1800 ft2 and appear to be pretty cheap with quite a small area for a fire. Buck for instance takes an 11" log for their 21 model. The Last wood stove I had for years took a 30" and this fireplace unit takes a 24" log. Any suggestions on the appropriate size and efficiency of models you know would be appreciated. Most say up to 70% without catalytic.
Most of the inserts or fireplaces I've looked at have 6" draw. I have an 8" stainless steel rigid double wall that is in very good shape. Cleaned it this year and was pleasantly surprised with its condition, hardly used. Would I be able to install an appropriate model fireplace insert using the existing flue without a 6" flue kit or do they make a model with an 8" draw?
Hope all have a good new year....LT
Not sure if I should replace the existing unit or try to find something efficient that will fit inside. Appreciate any suggestions.
Here's some spec's on existing model:
  • Fully insulated firebox (on select models)
  • White stacked refractory panels
  • Push/pull damper control
  • Barometric outside air damper
  • Uses IHP 8 DM (1700º) double wall air cooled wood burning chimney
  • Framing Dimensions: 38-1/4" W x 38-5/8" H x 22" D
  • Full Fireplace Dimensions: 35" FW x 29" BW x 21" H x 21" D
  • [Hearth.com] DESA Unvented (vent free) universal firebox
