Hi,
We inherited a dell point europa 75, model # GF75. It wasn't working-no display. We called Claude, tried fuses but there was no change, so Claude says it needs a control panel..Is that the same thing as a circuit board? And does anyone have one for sale, or know where I can buy it? Thanks.
Dexter do you know what a 8.8 on the display means its in both of my digital box's its a dell point gf75 2006, any thoughtsWhere abouts are you located? Ohio? If so, you prob talked to the right person already?
Welcome to the Forums.. There was one near me (Elyria Oh) last year that I looked into. IIRC it needed a new board?
Hi jay we have the exact same problem with our Europa as you do, did you get any info on what you were going to do with yours?Hi Lyndon, Did you have any luck finding out what the 8.8 error is?
I also have a Dell-Point Europa 75 2006 Model. My feed auger jammed one day while I was away. I came home to the stove making a sad sound as well as a burning smell in the hoper. Several pellets were scorched near the auger itself. The only way I could stop the stove was to unplug it and unplug the battery. After I cleared the jam and started it back up, it displayed 3 and 7 briefly on the control panel and then gave a -- and F5 error. The F5 error indicates a blown fuse which I replaced however no matter what I try I cannot reset or clear. Stove fans will run and ash auger will turn but thats all she does. The 8.8 error did not re-appear after I first unplugged it.
I'm thinking the Control circuit board needs to be replaced and if so where I can track one down. I live in Nova Scotia, Canada. These stoves seem very hard to locate parts for. Any ideas?
How did you make out with yours?
I recently purchased a house that has a Dell Europa 75 pellet stove. The door handle for the pellet stove is fastened with a set screw. This handle no longer will hold. It just falls off. I am looking for a replacement door handle. Does anyone know where I can get a replacement door handle for this stove?
I ended up taking the handle to a machine shop and he made me another. Good luck.I have the same problem. Did you get any replies? My handle still works but does not pull the door closed for a tight seal, so I fear we are getting fumes in house.
