I've owned the Dell Point Europa since 2006 and have had horrendous and "better" years trying to operate it. The "hook" that keeps me trying to make this product work is that when it's working, it really does seem to be a worthwhile stove. Currently, I am having a problem with the startup, which I have never had before.
Background: Since last year, I had noticed that two augurs in the lower ash extraction looked "stripped" or were wearing down. I asked the dealer how to repair it and they said that the augurs would cost $42 each and "were not hard at all" to replace. Two days ago, a professional car mechanic and I did it but the process of replacing the augurs involved a bit too much sanding and chiselling to be described as "not hard at all." We produced an assembly that looked like the original one...but I am not sure if there was something else involved in this replacement that could be causing the current problem. Maybe I'll need to shell out $280 for the entire new assembly, but anyway...
I re-installed the ash extraction two days ago, put pellets and starter in the burn pot, lit the stove and pushed the green "pellet" button. The unit only made a squealing noise at intervals, instead of kicking in with that humming noise that means the stove is in startup mode. I pushed the lower left red button and the "shutdown" blowers worked but the computer control panel somehow does not seem to engage the motor or whatever it is that triggers the startup.
I recently had to replace the F5 fuse. I am not sure if by doing this fuse replacement, I may have knocked a wire loose somewhere, but the panel looks about the same as usual.
I have called the dealer (sigh) and will continue to call them...but the service that I get on this stove is part of its problem. Over the years, I've tried to learn to do repairs myself, because it always takes the dealer a while to call me back. When they do answer, their helpfulness varies. There is also an accountability issue with this stove, where the dealer blames the manufacturer, who alternately blames the dealer, so that in the end it's hard to know who's responsible.
I know...a great puzzle in the quest for warmth. Way too much of a struggle than I bargained for, but as I said -- when this stove does work, it really does work well.
Thanks for listening.
