I have a Defiant Encore 1986 and am confused about the correct operation of the secondary air intake. It makes some sense that this flap should be open at startup and close down to regulate heat as the stove warms up. Lots of comments in the forums to this effect, but there are also a lot of comments that say it should be shut on startup, and the shut position seems to be the correct setting in the rebuild instructions (Serv_Encore_0028_2140) see quote below:
Has anyone a definitive answer on this, or can explain the technical operation of this secondary intake? Thanks in advance..
"secondary STEP 31: Assemble and install the secondary inlet assembly. Holding the secondary
air probe and thermostat assembly with the probe facing away from you
and the mounting tab at 12 o’clock, the tab on the end of the thermostat
coil should be at 4 o’clock position, loosen the lock nuts on the probe shaft
and adjust the coil tab and the mounting tab to the 4 o’clock and 12
STEP 31 Cont: o’clock positions respectively and re-tighten the lock nuts. Insert the
double bent end of the secondary air link through the hole in the tab end of
the thermostat coil. Insert the single bent end of the secondary air link
through the hole in the tab on the secondary air flap. Insert the secondary
air probe through the drilling in the stove back and secure with 1 each,
Phillips pan head machine screw (10-20x ¼”). Secure the secondary air
flap to the stove back with 1 each, Phillips pan head machine screw (10-
24x ¼”) and 1 each, shim ring. Tighten the screw securing the air flap
until snug and back off ¼ turn. Insure that the secondary air flap moves
up and down freely and that the flap rests at or near the closed position.
See figure A-8.
Fig. A-8 Positioning of Secondary Air Probe & Flap"
See figure A-8.
