Hello everybody,
I'm in the process of re-introducing a wood burning stove to my house. The house is an early 1950’s one story ranch, with basement. It was originally heated by a stove of some sort and over the years a gas furnace force-air system was added (1989 on the name plate). The walls are plaster/lattice and there is about 1030 sqft to heat (top level only), there is extra insulation in the attic rafters (but that maybe the only insulation in the house). My goal is to use less of the gas furnace which has trouble keeping up in late January through February. The stove was on the top level and centrally located, I still have a slate pad and faux brick insulation on the wall where the stove was located. Also I have the pipe running from my ceiling through my roof, although it needs inspection and possibly repair. Aside from that, I have narrowed my search of a stove to two Hearthstone models; the Tribute and the Craftsbury. What if any opinions can you add as to the quality, performance and maintenance of these stoves. Any help would be appreciated. Thnx.
