Short history...I had a OWB with hydronic heating...it was 17 years old and sprang a leak. Considered upgrading my woodstove from a QuadraFire 3100 to a PE Summit (with an ash removal system!), but wife wanted "even" heat which the woodstove does not accomplish. So, I was looking at a new OWB or a more efficient wood boiler (Tarm, EkoLine, Greenwood...). I will also heat all my domestic hot water this way.
Now, I would like to install the Eko in my polebarn (which I will also heat) and need a chimney. It will be simple, out the back of the boiler, thru the poolbarn wall and up. But, how far up do I need to go? The roof is probably 12/4 pitch. And the flue exit on the boiler is 8.25". Can I still use an 8" flue and how do I go from 8.25" to 8"?
Any suggestions on supplies (sources, brands) would be helpful.
Thanks,
Bryan
Thanks,
Bryan
