Building a new house in North Idaho. R45 ceiling, R23 walls. Daylight basement with R5 foam on the outside of the concrete walls. Around 1,800 square feet or so and two stories. Wood stove will be in the basement with the stove pipe going straight up (so pretty tall). Single wall pipe on the inside to class A once it hits the chimney.
Right now we have a 1980 doublewide with a Napolean 1450 (EPA, but older) as our stove. Wood is our primary heat source. We're able to keep the place warm, though regulating temperature can be tricky, especially at night.
I've been researching EPA vs pre-EPA stoves, cat vs non-cat, etc. People really seem to love Blazeking and I think the Princess would be sized about correctly for us.
I did find an older Princess stove with a cat for under $1,000. I don't know a lot about it, but it's a 8" flue. How would that compare to the modern Princess? Are long burn times attainable? Can I reduce the 8" flue to 6" without serious issue?
Overnight burns are great, as is being able to leave the stove for a day trip and get back to it going. We like to keep the main part of the house around 70, maybe a little under, and the bedrooms in the lower 60s.
I'd like to be able to have low output throughout the day, vs starting fires here and there. I currently am able to stock the stove in the double wide with small pieces throughout the day, which works okay. The stove in the new house won't be quite as convenient/central to monitor.
Are the minimum heat outputs lower with smaller models and higher with larger? Does this apply to other stove brands as well?
I'm also interested in Kuma stoves. Our neighbor seems to do pretty well with theirs. Though the 30-40 hour burn times (I doubt we'd use those that often) are unheard of with Kumas, vs fairly common with Blazekings.
Thank you!
Thank you!
