Hi, I am dealing with the pellet stove smoke stains on the exterior wall where the stove vents. It didn't respond to the dishwashing detergent so I will try TSP (trisodium phosphate), especially because I want to paint with something easier to clean then the Ace Royal exterior paint that it has on it now. Has anyone used Cabot's "The Finish" housepaint with Teflon component? I found out about it while searching online for anything like teflon that I could add to housepaint, or to paint with at all. It sounds perfect. I am planning to wax it afterward with Slipit, if it will take at all - I suspect that the teflon-based paint will resist the Slipit gel.
If you have had any experience using either of these products to make your exit wall easy to clean in the Spring, please let me know how it went for you.
I found the housepaint with teflon component at www.cabotstain.com (they call it "The Finish"), and the Slipit gel is at www.slipit.com
(For my part, I will post here if anything notable happens.)
