WOW! Set up with a 1000 gallon propane tank for storage. I had a few small fires over a couple of days, and then started to see what this unit will do. The control system is Awsome. I reloaded onto a hot coal bed, and watched the unit handle the changes. Primary and secondary air adjustments, induced air speed changes, O2 readings, and so on. I can't imagine trying to do this in a manual system without complete babysitting. I know, I paid for the automated system, but it really was only about 10% more than other systems I priced.
About the only problem I am having with the system is the circulator pump stays on much longer than I think it should, down to where the boiler temp is about 6 degrees warmer than the bottom of the storage tank. This really mixes up the stratification of the tank.
I guess they must use the "Lambatronic Control System" for different systems, because there are a bunch of functions that are not used with this boiler.
Very happy so far, keeping my 'under remodeling' 200 year old farmhouse warm, mostly from the heat from the storage tank. I should have it insulated in the next couple of weeks, so I'll see how my heat exchanger in the furnace keeps up.
Tom
Tom
