Instead of paying big money for an expensive 3-way valve, couldn't I put an aquastat before the return to the boiler and hook it to a small circulator in the bypass loop?
markpee said:Instead of paying big money for an expensive 3-way valve, couldn't I put an aquastat before the return to the boiler and hook it to a small circulator in the bypass loop?
markpee said:Can you go into some more detail? I would like to avoid ordering the Danfoss - how is it controled? Do you use an aquastat?
markpee said:So can it be that simple? I will attach the aquastat to the zone valve on the bypass loop and set the stat for 140? That's it? Do I need a balancing valve before the zone valve? If this is the solution, why do the manufacturers only mention the Danfoss?
markpee said:The Danfoss runs around $250, I can do the valve and Aquastat for around $150.
jebatty said:I had a gate valve which I installed, rather than a ball valve. Essentially, once you think you have it set for the right flow (more closed than open), you never touch it again.
Tony H said:Do you really need a valve ahead of the termovar ?
Contact Dave at Cozy Heat to get a price on the termovar.
