Damper with a Pacific Energy Spectrum?
Oct 24, 2024
41
Oregon
I've got a 1989 Pacific Energy "D" Super Series Spectrum stove that takes the 1/2" door gasket. It's hanging on by its last legs: The door is bent, one of the hinges had to be welded back on and the door is broken where it rides on the hinges so there's a stack of washers forcing it to stay up where it kinda-sorta should be. So using the standard size gasket is useless. I went up a size and still don't get a good seal. I've got a sort of franken-gasket which is 2-3 layers of gaskets and cement just to get it to close. Needless to say, the air control doesn't do a whole lot. Really, how I manage the fire is with the amount of wood. I should also say I burn 3+ year seasoned Shore (Lodgepole) Pine and Sitka Spruce because...that's all that's on our property. It burns FAST which is why it's actually one of the lowest BTU-producing woods. I've got some fir and ash that I squirrel away for the dead of winter to burn overnight. Earlier today I had a fire so hot that I got that burning paint smell off the stove pipe and the Class-A chimney through the roof was HOT. I actually got a glass of water and threw it in there to put the fire out. I had three larger pine logs in there—a totally normal load for a modern stove—but I got greedy! I get stressed out because we have a really long chimney and it's actually started to sag noticeably when you look down it. You can't visually inspect the exterior because it's encased in a drywall beauty box as it passes through the house and crawlspace. A certified wood stove installer company said that that was normal for 30+ year-old chimneys and as long as it wasn't touching anything it was alright, but I'm afraid of getting it hot and making it sag even more.
My wife and I have decided that this summer we're going to get a modern one, but we're going to have to save up. I've read a lot of mixed reviews with the U.S. Stoves, Cleveland Stoveworks and Ashleys and such that Home Despot and Lowest carry. We'd like to save up and get something that's just going to work. Not sure what brand yet. We need to survive this winter without ruining our chimney.
My thinking is to install an old-school cast iron damper like the stoves of yore. I robbed one off of another stove that a guy heated his house with for 40+ years and it was only installed 4.75" up off of the stove outlet. Basically just enough room for it to swivel. I've got a small section of single-wall pipe I was just going to put in-between the stove and my double-wall pipe. I've read multiple places that 18-24" would be normal, but I don't really want to mess up my nice double-wall stove pipe by putting one in up high and I've read that putting them in double-wall requires some creative engineering. I'll never close it down 100 percent because, as mentioned earlier, my door seal is worthless, and I'd like to avoid CO poisoning, but if I get a runaway fire or something, it'd be nice to be able to slow it down or hopefully even stop it quickly.
It can be done. The Duravent DVL stove pipe damper is built into the 6" flue collar adapter. As long as the damper doesn't bind it's ok to put it in a short section of pipe.
PE still makes good stoves. The Spectrum is now the Super. With proper operation, a new one should be good for the next 35 yrs. I would replace the chimney pipe also. It too has a finite lifespan.
If the interior of your chimney is sagging that is really bad and I absolutely would not be using it in my house
Reactions: begreen
Yes, this is like trying to convince oneself that it is safe to drive a car that has the brake system tied together with baling wire. The whole system needs replacement.
For a value stove, look at the Drolets. If the PE Spectrum has been pushed hard to heat the place, then consider a larger 3 cu ft stove. The savings on the Drolet can be allocated to replacing the chimney system.
Would the Duravent one work with regular double wall pipe? I've got one of those sliding ones you hook to the Class A and slide down to your stove. I had originally built myself a single wall one, but decided I wanted double for the safety and extra draft...but now the draft is insane. I've also noticed Selkirk sells one.
The stove was installed by a certified company that inspected the chimney when they did it. We've got a three story house and they said they all sag when they're that tall.
There is no regular double-wall stove pipe. The brand should match for proper connection.
At 30+ years, it is likely at end of life. With the stove and flue of a similar age and deteriorating, it's playing with fire.
Reactions: bholler
Yes double wall connector pipe like that will hook to pretty much any chimney. But you should really have a different company inspect because no sagging is not normal
So, another CCB company came out and they said the hole in the second floor and the hole in the roof for the chimney don't match up by design as part of the house's floor plan, so it was installed purposefully with a bend. Where they wanted the stove placed and where they needed to put the roof flashing necessitated that and it passed county inspection and received a permit. I just don't see how this kind of prefabricated chimney can bend, though. I've never seen curved Class A for sale. That doesn't mean it doesn't exist, obviously, I don't know crap about crap, but.
I think it is time to post a few pics.
Unfortunately, I don't know how to get a better picture. This is looking straight up to the swivel cap. I wish I'd put something reflective up there. You can see on the right a little bit of a semicircle. My guess is that is a joint between two Class A sections.
  • [Hearth.com] Damper with a Pacific Energy Spectrum?
I don't see much if concern. But I'm not the professional. Yet I meant pics from the outside to see the set up and the sagging.
Here's the problem. The sag is in this, I call it a beauty box, but I don't know a whole lot about it. The only way to look is to drill a hole and use an endoscope in the drywall or remove the drywall. Or...send a professional camera down the chimney from above? I've been told chimney companies have them for masonry chimneys.
I got up into the crawlspace, but it's so narrow and the way the trusses are l, I wasn't able to get close to peek down the thimble.
Hm. If you're concerned about the safety then yes, get a camera inspection by a certified sweep.
