damper question
weezer4117
251
central In
i am going to install a damper inside of my metal chimney. the question is do i mount it close to the stove or farther up the chimney?
I think most are placed near the stove for convenience. I think mine is about 14 inches or so above the stove top.
Next question: Is your stove a new EPA model or an older one? Most new stoves don't recommend a damper unless there is an extreme overdraft. I have one in my pipe for the purpose of slowing down a down draft when the stove is not in use so that the family room doesn't smell of creosote. But I NEVER use it during normal operation.
pen
pen
Agree. I didn't have a damper for my old VC, and didn't put one on the new Oslo piping either. Never had an excessive draft problem with my relatively short chimney. I can see the need for a damper only if there is a demonstrated overfiring problem that's related to excessive draft.
As for blocking the down draft smell in the offseason, a damper sounds like it would work as long as it seals well enough. I use a 6" thick foam rubber plug that fits tight in the pipe, and that I can put in through my cleanout door. Works great. But, I DO have to make sure I remember to take it out before I try to light 'er up!
the stove is very old with a 18' chimney. i have a problem maintaining the same temp or close to it so i thoght a damper would allow me to control the temp better. it seems like i go from 300 deg to 600 ALL the time. i would like to find a way to keep it in the middle with less monitoring. i burn several types of hard wood so im sure that plays in somewhere, but i shouldnt have to play with a 300 degree gap all the time.
Ours is 18-20" up from the stove top...double wall pipe take little finessing but you can do it.
ripe said:
barometric damper effects automatic draft control
What happened to the post about "turbulation"?
That is one super-de-duper word :ahhh:
pen
