I have an Ariens 27-ton splitter with the cylinder rod stuck in the out position. I had it tuned up before storing and all fluids replaced, been starting it monthly and cycling the cylinder rod. It just got stuck in the out position, tried adding hydraulic fluid and ran the engine a while and it still didn't work. It's really hard to see the oil on the dipstick because it's so clear, even on paper towel, but I'm pretty sure it's between the lines right now. Is there a trick to get the fluid back in the system if it ran low?
