All,
As I draw closer to finding a competitive quote for installing the word burning insert that I've chosen (Pacific Energy Neo 2.5), I've hit what I hope isn't a deal-breaking snag:
I remeasured the firebox area and determined that, at 20 inches depth, my firebox width is 25"--1.25" short of the 26.25 needed for the PE Neo 2.5. I won't say that I'm heartbroken--because, after all, I am talking about a fireplace insert--but I really liked a great many things about this insert and had my mind made up, so now I'm going through the denial phase.
I searched as best I could but got a lot of false positives related to modifying firebrick, so I pose this question: is it possible--and wise--to cut a right-angle notch into the fireplace brick (see rudimentary finger drawing, below) to accommodate this insert of my choosing?
Unfortunately PE doesn't offer a projection kit like Osburn does for the Matrix (which, even with their 4" projection option, just barely won't fit)
I'm somewhat prepared for feedback like "why don't you instead buy a ______" so I'll add that I'm looking for the following:
A - 26.75"
B - 35.5"
C - 22.75"
D - 20"
E - 23.5"
F - E + 19" hearth extension
G - 34"
H - 7"
As always, thanks for your help.
![Cutting or grinding brick in fireplace to fit insert? Cutting or grinding brick in fireplace to fit insert?](https://www.hearth.com/talk/data/attachments/184/184484-6aa5b94d2aefef93c085d1824d1e643e.jpg)
![Cutting or grinding brick in fireplace to fit insert? Cutting or grinding brick in fireplace to fit insert?](https://www.hearth.com/talk/data/attachments/184/184485-3936b9d36e369f1177ddbed1867f13c8.jpg)
- An insert that can as much as possible offset the reduced use of my (really old) furnace in my small ranch-style home, and:
- Has a firebox of at least 2 ft^3 and accommodates 18"+ wood (preferably "north/south")
- Has the potential to run 8 hours when loaded and at optimal temps
- Qualifies for the $300 biomass credit
- Isn't more than $3,000
- Doesn't require as much involvement as I've read some catalytic inserts do (Regency CI2600)
- Is as close to being flush-mount as possible. I have a full 19" of tiled hearth extension, but the issue is that my living room is much wider than it is long so I don't want the insert to stick too far out and I like the look of the flush mounts more than those that aren't (but I do also like the idea of warming a pot of soup or a cup of coffee/tea on the ledge like my family have done with their Napoleon)
A - 26.75"
B - 35.5"
C - 22.75"
D - 20"
E - 23.5"
G - 34"
H - 7"
![Cutting or grinding brick in fireplace to fit insert? Cutting or grinding brick in fireplace to fit insert?](https://www.hearth.com/talk/data/attachments/184/184482-71df2fd04c29d3716e2cb1775c0cacec.jpg)
![Cutting or grinding brick in fireplace to fit insert? Cutting or grinding brick in fireplace to fit insert?](https://www.hearth.com/talk/data/attachments/184/184483-748c3b7264af876986ca6c42991c90a3.jpg)
