GolfandWoodNut said:That looks a little scary zap. Can't you take your winch and pull it sideways? It looks like it would fall the right way if you cut the maple, but being that close to that much weight scares me. I have used a come-along on some like that. Now I have the Bobcat and I could just give it a push. Another option is cutting the big boy a couple of times from the bottom. Sometimes that is enough to get it moving. I assume you have tried the winch already since you have done that before.
wood spliter said:Its hard for me to see clearly. If I was going to cut the Maple I would not notch it. I would do a slow rip cut than get back when it starts to go. I don't like to work under hung trees so I would do back cuts on the dead tree. That's my eye from a distance hope it helps some
wood spliter said:That even sounds safer Zap!
Beetle-Kill said:Good call Zap. Even better would be a tree saver+20' chain+ Rhino, and drive off in the opposite direction. Yank out the bottom a few feet, and it should go. Stay safe with that one.
smokinjay said:Is your winch strong enough to pull the butt end around?
savageactor7 said:As long as its not a threat I'd go on to the next tree.
zapny said:smokinjay said:Is your winch strong enough to pull the butt end around?
We will find out Wednesday, I might take the old green truck then I might pull it home.
zap
smokinjay said:zapny said:smokinjay said:Is your winch strong enough to pull the butt end around?
zap
I like that style. I have pulled some pretty big trunks for milling.
