Propane experts, I need some advice and hope you'll bear with my not-quite-a-stove thread...
I've got a 6x12 trailer which I've converted into a travel trailer, and I ran propane hoses through the interior for my three outputs. One of the outputs works perfectly, the other two seem to have low pressure, and I'm at a loss as to why.
Here is the setup:
1. The exterior has two 20lb tanks with a Flame King automatic changeover regulator: .
2. I've got a 5' Camco hose running from the regulator, through the wall of the trailer via a waterproof fitting: . (I've checked the tightness of this fitting and ensured it's not pinching the hose and thus restricting supply.)
3. Inside the trailer, the same Camco hose comes up and into a Aupoco Y-splitter: .
4. The right-side of the splitter comes up into a Camplux water heater, which works just fine. This is the working output.
5. The left-side of the splitter connects directly into another, identical Y-splitter: .
6. The top (right) side of this (second) splitter comes up out of the countertop: , and here it terminates in a QCC1 Acme nut. The picture shows a manual, yellow valve before this nut - I've removed that since taking the photo. This QCC1 nut is basically the same thing you'd find on top of a 20lb propane cylinder. It has a built-in check valve that's activated (opened) by the male part of the propane accessory you screw on.
7. The left-side of the splitter goes into two, 12ft (each) Wadeo hoses.
8. The hose terminates exactly the same as the one going through the countertop, described in point #6: , .
When I attach my Partner Steel stove to either the QCC1 nut in #6 or in #8, I hear a tiny trickle of propane coming out, but it's not enough to even light the stove.
I initially thought the issue was with the QCC1 connectors, and their valves being set too deep and thus not being opened by my stove's male counterpart, but that's not the case. I even took one of these connectors and completely drilled out the inside to have an unobstructed propane flow, and it made no difference. Best as I can tell, the problem seems to be low propane pressure. This is where I'm lost.
I've checked every single connection/component for leaks using both a handheld detector (which works, I've checked) and a permanently-installed and always-powered propane detector in the trailer itself. There are no leaks.
Could the problem be an obstruction in one of the hoses/splitters? Is the problem in my "design," or perhaps air trapped inside the hoses? Any ideas on what I can/should do?
For what it's worth, yes, I'm fully aware that the water heater should not be used in an enclosed space, propane lines would be best ran outside, etc. Please - I'm not interested in discussing that here.
Here is the setup:
