We moved to a home that was originally owned by an engineer. It appears he loved to DIY as there are a lot of nice little things he has done with the house. When I hear DIY, I generally think was probably done poorly but this guy was pretty impressive from what I have experienced thus far.
One of the things he created was his wood stove. Rather than blindly trusting that this was safely designed, I wanted to get some input on what you guys think. I know there is likely optimal dimensions for firebox design, flue diameter, etc which likely has a huge effect on efficiency
Our home is two stories plus a basement. Home built in 1990. Primary heat source is LP - this stove is just supplemental. Previous owners were here about 10 years- noted to not use stove very often - usually just on weekends. No idea on use frequency prior to that. Stove felt to be built by original owners so it is quite old. Stove is in the basement which is unfinished- cinder block walls, concrete slab, sheet rocked ceiling. The chimney traverses all 3 levels in the middle section of the house- one face of it is exposed on the 3rd floor but otherwise it is inside. There is a second flue inside but it is not used. Chimney was recently inspected and in good condition without any significant creosote buildup.
The stove is square and constructed from 1/8" steel. External dimensions are 33x38x30". Firebox dimensions are W29 x L28 x H26. As best I can tell, around the firebox there is about 4" space in each dimension except in the back where the air ducts are located. No idea if there is anything inside there. The floor and half of the walls are lined with standard sized firebrick. There is no exhaust damper. Exhaust flue is 8" diameter. There is a small square shaped piece of metal below flue (photos). There are two rotating knobs for draft control.
On the side, there are two 8" openings for air ducts which feed into the first floor HVAC. Air is ran not by the hvac fan but by a fan several feet from the stove. Heat output is very good, albeit noisy. It can easily keep the first floor toasty but getting the warmth to the second floor is more of a challenge. There is a an access panel on the back to access the inner airflow section.
A few of my concerns-
Do you think it is worth staying with this stove or would I be better served upgrading to a newer, more efficient model?
Creosote is always a concern and with having a 3 story chimney, I really would prefer to run hotter to keep temps up. I have NO problem quickly getting flue temps (measured externally of course) to 350+ and can easily get to over 500 with the draft control open at 3/4, especially with a fast burning wood type.
In regards to the air duct and steel construction, any issues you see with running this occasionally hot (600ish) to try and burn off any creosote buildup? Definitely would have fan on - I've seen the duct thermometer get close to 120C (250F) when I have not had the fan on
Is it more efficient with a firebox of this size to pack it full and control burn temps vs having a smaller fire and letting it open?
Other than it being a devourer of wood and smoke getting out when I am first getting the fire started and open the door too quickly, I am happy with the stove. We have plenty of wood on my property from the occasional downed tree.
Other thoughts? Thanks everyone!!
![PXL_20201115_223058379.jpg PXL_20201115_223058379.jpg](https://www.hearth.com/talk/data/attachments/267/267240-28ab39de8e55e150c19d2454a4ce64f8.jpg)
![PXL_20201115_223918525.jpg PXL_20201115_223918525.jpg](https://www.hearth.com/talk/data/attachments/267/267237-c1994febdf106cb439029cde627e18e4.jpg)
![PXL_20201115_223638677.jpg PXL_20201115_223638677.jpg](https://www.hearth.com/talk/data/attachments/267/267238-bb4cc6a7c33b1a5066b8f7084466fcf2.jpg)
![PXL_20201115_223106318.jpg PXL_20201115_223106318.jpg](https://www.hearth.com/talk/data/attachments/267/267239-c31c8c18e6f4ecb887d5df128ec4fe45.jpg)
