hello all,
I have purchased (and am waiting on) a cubic mini wood stove for a cargo trailer that I converted into a sort of super-insulated tiny house. the dimensions of the cubic mini stove are 11" wide, 12" tall and 10.5" deep. I suppose those dimensions include the feet and little rail around the top. I don't need either of those. I have an old fireproof safe that has inside dimensions of 11.5" wide, 14"tall and 17" deep. outside of the interior safe dimensions is two inches of some sort of stone material with steel sheeting on the inside and outside. (I know about the "stone material" because the safe combination/locking part had been broken by a relative who had forgotten the combination - i drilled thru to make a hidden bolt setup to lock and unlock it).
my thinking is that (most importantly) anything around the stove would be protected, and additionally, the safe rock and steel material would absorb heat and release it over time. also i could shut the door if i wanted a quick and safe shut down. obviously i would have to use a good hole saw bit to make the circular hole for the stove pipes.
questions are would this likely be harmful to the stove due to too much insulation? (I've seen stoves installed in fireplaces with relatively little clearance so i don't know that this would be an issue.
and also would all that insulation keep the stove from putting out optimal heat or would the heat simply be released more slowly?
thanks for all help![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
thanks for all help
